1. djm1990's Avatar
    Can I plug a elm327 obd usb device into my s4 and use the app dash command with it
    10-27-2013 08:15 AM
  2. Adamsberg's Avatar
    Can I plug a elm327 obd usb device into my s4 and use the app dash command with it ...
    Dash Command claims to connect via Bluetooth, like most of the OBD apps.
    As client USB device the Elm USB can be plugged into the phone ... but the problem seems to be to find an app for the communication.
    10-27-2013 11:37 AM
  3. djm1990's Avatar
    It does say on das command that it can connect via usb but I have yet to see anyone do ot well say they have lol
    10-27-2013 01:03 PM
  4. djm1990's Avatar
    Just tested it works great
    Adamsberg likes this.
    10-27-2013 02:14 PM
  5. Adamsberg's Avatar
    Good to know
    10-28-2013 03:17 AM
  1. NEXUS 7 2013 Flimsy USB Cable
    By Atiya in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-27-2014, 02:16 PM
  2. Galaxy Note replacement usb port
    By alistairfellowes in forum Samsung Galaxy Note
    Last Post: 10-28-2013, 01:48 AM
  3. USB OTG Does Not Work on Verizon Galaxy S3
    By briguy#AC in forum Verizon Galaxy S III
    Last Post: 10-27-2013, 12:25 PM
  4. How to turn off usb stability detection ?
    By Callixtus81 in forum Samsung Galaxy S3
    Last Post: 10-27-2013, 12:14 PM
  5. USB 3.0
    By emiinn in forum Samsung Galaxy Note 3
    Last Post: 10-27-2013, 02:28 AM
