1. Cool Jeff's Avatar
    Hi!
    I got a Sandisk 16gb class10 yesterday for my S4,I am very deceived by the writing speed as it doesn't beat the 8.5mb/s writing speed.
    It takes long minutes to transfer a 1gb file.
    Tested on the S4 with SD Tools and gave me 8.5mb/s too.
    Tested directly on PC with the adapter and got a 20mb/s that falls to 5mb/s in only 3 seconds (H2testw)
    I talked to the salesteam of Virgin Lebanon and they said ''it's perfectly normal'' while I am convinced it's way slower than it should.
    I even got a low 2.5mb/s when transferring from my laptop to the S4.
    So is it normal or not for a class 10 sandisk Ultra?
    10-29-2013 12:58 PM
  2. Haalcyon's Avatar
    8.5MB/s is a very normal writing speed for the Sandisk Ultra. A Sandisk Extreme may double that.
    My scores:
    Ultra:
    Extreme:
    10-30-2013 06:14 AM
  3. ScottsoNJ's Avatar
    I know it has been written about problems with SD cards and the S4. So I went and bought a Samsung Class 10 sd card for my S4. Works great
    10-30-2013 08:13 AM
  4. Cool Jeff's Avatar
    Geez I thought any class10 would give 20mb/s
    Finally it's better to get an internal memory like HTC One as it's 32gb and 3x faster than my sandisk
    10-30-2013 08:51 AM
  5. CehowardNote7's Avatar
    Well, I was on the S4 bandwagon with Tmobile. However, I was reading how fast the 9gbs can go on the 16gb model. Returned the S4 and tried to wait for Tmobile to get the 32gb S4. It never happened, but the Note 3 came out, and I went there. I would have an S4 if they had came with the 32 and 64 gb models. Internal memory is way faster then external memory.. Sd cards are for vids and pics...
    10-30-2013 04:05 PM
  6. Haalcyon's Avatar
    Well, I was surprised. I thought the USB 3.0 speeds were really gonna knock me back. Not. ...but they're faster than USB 2 so I'm not complaining.
    10-30-2013 04:32 PM
  7. Cool Jeff's Avatar
    I think people should stop claiming ''class 10? it's blazing fast on a smartphone'' because it's not!
    It's just slightly faster than a class4,if I knew, I would have bring a 32gb class4 instead of a 16gb class10
    10-31-2013 02:57 AM
  8. Haalcyon's Avatar
    Well, 17.6MB/s vs. 7.9MB/s in write speed would be considered substantial to some and not mistakenly so. The questions remains how much of a difference one would see in between class 10 and the lower classes.
    Note 8.0
    10-31-2013 08:46 AM
  9. Cool Jeff's Avatar
    Yeah but you are talking class10 extreme vs class10 Ultra,all class10 should be at the same speed,classing cards by class is a mistake then.
    A microsd class10 ultra compared to a class4 is just about an equivalent of a class 5.5,only the ''extreme'' is a true class10
    11-04-2013 03:05 PM
  1. ASUS Memo Pad 10 - slow battery charge
    By Kelly Martin Ozias in forum ASUS MeMO Pad 10
    Last Post: 05-18-2014, 09:47 PM
  2. Massive Barge On San Francisco Bay Likely Secret Google Facility
    By ludesleep in forum General News & Discussion
    Last Post: 10-29-2013, 12:10 PM
  3. Replies: 0
    Last Post: 10-29-2013, 11:24 AM
  4. Disable auto-on with book cover?
    By TekNinja81 in forum Samsung Galaxy Note 8.0 Tablet
    Last Post: 10-29-2013, 11:15 AM
