1. NomenNescio's Avatar
    My earphones, those that came with the phone, have suddenly gone mute on one side - the right. They worked perfectly fine so far, and the only thing i can remember having done with them is using them in my computer, which i have done before without problems, because my headphones also failed....what can I do?
    11-04-2013 03:13 PM
  2. HPferoxCraft's Avatar
    Go under settings-device-accessabillity and scroll down and see if mono is ticked, if it's not check Sound Balance right above that. You could also try Adapt Sound and see if that does anything.
    11-04-2013 05:34 PM
  1. Jaybird Blue Buds X Bluetooth communication problem - advice needed!
    By rosemore in forum Verizon Samsung Galaxy S4
    Last Post: 05-21-2014, 07:13 AM
  2. Sony Xperia ZL - IR Blaster Problem
    By coolrevi in forum Sony Xperia ZL
    Last Post: 02-04-2014, 11:36 PM
  3. Issue using earphones on new phone
    By mjdelaney80 in forum Samsung Galaxy S4
    Last Post: 11-04-2013, 01:07 PM
  4. Problem w/Volume Notification
    By BigDogDVJ in forum Motorola Droid MAXX
    Last Post: 11-04-2013, 12:13 PM
  5. Galaxy touchscreen problem
    By Paul Birlea in forum Samsung Galaxy SIII I9300
    Last Post: 11-04-2013, 06:51 AM
