1. arcjeeper's Avatar
    11-05-2013 08:20 PM
  2. UJ95x's Avatar
    It certainly doesn't have the best but more than enough for me. I can't drain the battery in one day
    11-05-2013 08:35 PM
  3. Kayla Smith3's Avatar
    I love my S4. Im on my phone a lot because I am a indirect store manager. My battery life is ok. It last about 6 hrs but I use it heavily with email, chat, apps, music, videos, and talk through out the day.
    11-05-2013 09:21 PM
  4. indyirishone's Avatar
    What is the secret? I just got my s4 yesterday. (Had the s3)
    Overnight, while I was sleeping (ie NO USE) my battery went from 97% to 54% in 7 hours.
    I charged fully this morning and stuck in my desk drawer, 100% down to 80% in 3 hours of no use
    Only connections on are wifi and sync no gps or bluetooth.
    Help!!!
    11-11-2013 10:23 AM
  5. STSVA's Avatar
    Help!!!
    What does the settings battery section say is using the battery by %? That's usually a good place to start in figuring out why you've got excessive battery drain. For what it's worth, I use Snapdragon's Battery Guru app and think that helps a lot; it basically controls app syncing and can also control when wifi is on if you want that. I also use the Lux Auto Brightness app to control screen brightness. I used to be concerned about Google Services and location services, but those don't seem as much of a problem now, possibly due to updates such as Android 4.3.
    11-11-2013 07:26 PM
  1. Restore Note 3 from S4 HELP
    By tony_ha in forum Samsung Galaxy Note 3
    Last Post: 05-26-2014, 05:53 AM
  2. Android OS Draining my Note 8 Battery when Locked
    By pmcdunnough in forum Samsung Galaxy Note 10.1
    Last Post: 11-06-2013, 04:14 PM
  3. Replies: 3
    Last Post: 11-06-2013, 04:44 AM
  4. Replies: 1
    Last Post: 11-05-2013, 07:23 PM
  5. Samsung Galaxy S4 - Just got a replacement S4 from Asurion
    By fre1102 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 11-05-2013, 07:03 PM
