1. Michelle Baker3's Avatar
    I just got back from Thailand. While over there I used a local sim for mobile data. Now when I search networks for Optus (im with Dodo), and select it, I get the message "unable to change networks while data service in use. Stop using current data service and select another available network? "
    Any ideas on how to fix this?
    11-08-2013 10:32 PM
  2. STARGATE's Avatar
    Welcome to the forums! :thumbup:
    Did you already pulled out the other SIM and check the networks section on the menu?
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    11-08-2013 10:45 PM
  3. Michelle Baker3's Avatar
    Thank you
    Yes I did and that hasn't helped at all. Maybe I will need to call my provider and talk to technical support.
    11-08-2013 11:04 PM
  4. STARGATE's Avatar
    Have you checked your roaming settings, just in case?
    11-09-2013 12:26 AM
  1. Can I get back to rooted after the latest Verizon update? Help!
    By mcat66 in forum Verizon Samsung Galaxy Note 3
    Last Post: 11-14-2013, 11:07 PM
  2. Please help! !!
    By Teddy Jenkins in forum Samsung Galaxy S4
    Last Post: 11-13-2013, 06:31 AM
  3. Help narrow the choices!
    By turbodmac in forum General News & Discussion
    Last Post: 11-08-2013, 10:23 PM
  4. Moto X - T-Mobile Version vs DE
    By Chris Kilburn in forum Moto X (2013)
    Last Post: 11-08-2013, 07:40 PM
  5. T-Mobile and the nexus 5 info
    By Hasbrobot in forum Google Nexus 5
    Last Post: 11-08-2013, 07:35 PM
