1. Sanyad's Avatar
    I entered this (*#0228#) on my dial pad and there it showed battery percentage ..and there is something like quick start down there ..i pressed it and suddenly my battery percentage changed ,earlier it was 56 now it became 26 ..what to do i am worried ..i tried restarting my phone but it was still the same ..and it seems from that day my battery life has decreased
    11-10-2013 02:33 PM
  2. Eclipse2K's Avatar
    Just charge the device up and don't worry about it unless it continues to be worse. Under Settings > Display you should be able to enable a Battery Percentage meter for the notification bar. I had that feature on the Note II. The Quick Start may have caused a drain but my opinion is that it most likely confused the meter more than anything else.
    Sanyad likes this.
    11-10-2013 07:33 PM
  3. Sanyad's Avatar
    Did u had the same problem ??
    11-11-2013 01:01 PM
  4. Sanyad's Avatar
    Did you had the same problem ??
    11-11-2013 01:02 PM
  5. Eclipse2K's Avatar
    No but I've seen others mention this before and that's normally the case.
    11-12-2013 07:31 PM
  6. Sanyad's Avatar
    Ok ..thanks for the information
    Eclipse2K likes this.
    11-13-2013 03:16 AM
  1. Replies: 82
    Last Post: 01-16-2014, 09:48 AM
  2. Google Wallet using my battery - Wakelocks?
    By appmy in forum Moto X (2013)
    Last Post: 11-11-2013, 03:05 PM
  3. Best battery tools?
    By EricandSuebee in forum Moto X (2013)
    Last Post: 11-11-2013, 09:10 AM
  4. What is this unknown app killing my battery
    By Xtremeyouth1 in forum Sprint LG G2
    Last Post: 11-10-2013, 12:01 PM
