1. Timmevs's Avatar
    Since last couple of days my s4 battery goes down from 30% to zero in a matter of minutes. Why?
    11-13-2013 03:44 PM
  2. NexusNick123's Avatar
    Hi and Welcome..Do you close out all you apps when you are done...Like from the task manager..Also take a screen shoot of your battery and post it so we can see whats going on
    11-13-2013 03:56 PM
  3. chrisblore's Avatar
    I'm getting exactly the same thing, ever since my phone updated to Android 4.3 on Monday.
    11-13-2013 04:03 PM
  4. ladyhaly's Avatar
    Sounds like another battery defect problem... Mine started acting that way when my S4 was just two months old. A factory reset didn't help and if the battery failed me during the reset, I could have bricked my phone. Samsung has acknowledged the presence of the problem as it is quite widespread. You can Google and see articles about it. Battery is under warranty for 6 months. You can have them replaced by Samsung. Either way, you need to replace the battery ASAP or the thing could leak and explode.
    Sent from my GT-I9505 using Tapatalk
    11-13-2013 08:43 PM
  5. Timmevs's Avatar
    Thanks for the replies so far. Attached is screenshot of my battery issue from last night
    I don't close apps via task mgr. Shouldn't normally have to right?
    Come to think of it. Mine also started acting like this after 4.3 upgrade.
    Tim
    11-14-2013 08:34 AM
  6. Timmevs's Avatar
    All,
    Thanks for the inputs. Took my phone to a Samsung service center and ... guess what ... the battery is swollen. Getting a free replacement. Hopefully live can return back to normal then. (-:
    11-25-2013 02:01 AM
  7. clevin's Avatar
    here is my analysis on how to really really prolong the battery life:
    http://forums.androidcentral.com/goo...tery-life.html
    11-25-2013 06:01 AM
  1. Replies: 4
    Last Post: 05-08-2014, 09:24 AM
  2. Battery Life & Tips
    By Don164 in forum HTC One M7
    Last Post: 11-17-2013, 04:33 AM
  3. How to use Chrome as a pen window! no root needed
    By qualifyordie in forum Samsung Galaxy Note 3
    Last Post: 11-14-2013, 05:26 PM
  4. MicroUSB to Ethernet...
    By David Tesler in forum Samsung Galaxy S3
    Last Post: 11-13-2013, 11:37 PM
  5. do themes for s3 mini apply to all applications?
    By anonymous92374 in forum Samsung Galaxy S3 Mini
    Last Post: 11-13-2013, 02:15 PM
