1. Mitri360's Avatar
    I know that it uses more power because of pushing it to the tv and powering the phone. But I'm using the official charger that came with my s4 and the battery goes quickly.
    It's running the screen, brightness is all the way down to 0 and whatever I'm doing and I want to know is there a way to either get the screen darker without darkening the mirror(screen filter darkens the mirrored) or just shut off the backlight completely? Or is there a charger that will charge and do the mhl power also?
    11-14-2013 01:31 AM
  2. Armifera Fatum's Avatar
    MHL adapters usually have a charging port on them.. You connect the charger to the MHL & then MHL to the TV & it should charge your phone as your streaming on the TV. I have the OEM from Samsung I picked up for $40.00 & it works just fine!
    11-14-2013 06:42 AM
  3. Mitri360's Avatar
    I'm putting the charger in but it's not charging with the adapter.
    11-14-2013 04:39 PM
  1. Did wireless charging kill my NX5 screen!?!?
    By skippyrulzzz in forum Nexus 5 Accessories
    Last Post: 11-18-2013, 07:29 AM
  2. samsung i9300 not charging but sync with pc / kies okay
    By Seb Tyrer in forum Samsung Galaxy SIII I9300
    Last Post: 11-13-2013, 06:48 PM
  3. charge samsung s4 ac adapter
    By notureaveragemiss in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 11-13-2013, 12:39 PM
  4. Best buy has the back charging covers
    By fkpalm in forum Samsung Galaxy Note 3
    Last Post: 11-13-2013, 12:19 AM
  5. Phone Won't Charge!
    By katelewis95 in forum Samsung Galaxy Precedent
    Last Post: 11-12-2013, 09:59 AM
