1. Peter Hammett's Avatar
    So I know how to change the notification sound for most apps like text and gmail. However, some apps like Snapchat don't have any option for an app specific sound, just notification on or off. Is there a way to get android to use a different sound for those apps? So I'm looking for a way to set a sound specific to Snapchat, not a way to upload new ringtones. Thanks.
    11-17-2013 11:00 AM
  2. Haalcyon's Avatar
    Welcome to Android Central!
    That idea does sound nifty. An app or other mechanism that will allow you to individually set notification sounds for your different apps. I've not come across anything like that in my travels but perhaps some of our other members have.
    11-17-2013 11:59 AM
  3. mhinc's Avatar
    I have not come across anything either, if the developer did not include a way to change the notificaiton then I think you are stuck, and I can't see there being an app developed that would allow you to do this as it would have to change the app itself, unless it was over ridden somehow.
    Personally, I have an issue when I log into my Facebook on my S4, when it first loads it makes my Default SMS message sound, and there is NO way to change that, makes me made because it doesn't fit what so ever. So I hear where you are coming from
    11-17-2013 12:14 PM
  4. Peter Hammett's Avatar
    Well glad to know that I'm not the only one suffering from this. It is frustrating indeed because most of my apps have a distinct sound, but a handful of them just use the default notification sound, so there is no way to know if it's a Snapchat or something else. Sounds like I'll just have to hope Snapchat builds in the notification settings down the road.
    11-17-2013 12:48 PM
  5. ouchmyprostate's Avatar
    That would be such a great feature. Any developers reading this, please make an app!
    11-17-2013 06:43 PM
  6. Lanhoj's Avatar
    LightFlow supports Snapchat & a ton of other Apps.
    11-17-2013 06:49 PM
  7. Peter Hammett's Avatar
    Thanks. But I'm trying to change the sound and not the light.
    11-17-2013 11:40 PM
  8. Peter Hammett's Avatar
    I'll try posting in development forums. Maybe there is already something out there for other devices.
    11-17-2013 11:42 PM
  9. mhinc's Avatar
    Peter you may be going about this the wrong way. Instead of looking for a 3rd party app, try going to the actual developer of Snapchat and suggest being able to change the notification in a future build. I think you would have a much better response that way.
    11-18-2013 11:05 AM
  10. Lanhoj's Avatar
    LightFlow controls alot more than the light.
    I've used it on a ton of devices since the Nexus One both with & without LED indicators.
    It can control:
    -LED
    -sound
    -vibration
    -camera flash
    -reminders
    And can also push Notifications to:
    -DashClock
    -Pebble
    11-18-2013 02:27 PM
  11. Skivey's Avatar
    ^^ amazing!
    This works, its costs 1.49 but its worth it. Friggin awesome.
    11-26-2013 04:56 PM
  12. ashleestorm117's Avatar
    I didn't have to install any app I just changed my default ringtone to what I wanted my snapchat notification to be and customized all my other apps to their own sound. Easy peezy
    04-30-2014 12:49 PM
  13. alia el chamy's Avatar
    how did you do it?
    01-31-2017 11:12 PM
  1. How to turn off gmail notifications
    By Karmakop in forum Motorola Droid MAXX
    Last Post: 11-28-2017, 12:38 PM
  2. [APP] [FREE] Bad Joke Sounds
    By Atukapps in forum Android Apps
    Last Post: 11-17-2013, 09:41 AM
  3. Verizon Note 3 camera shutter sound.
    By redimpala01 in forum Samsung Galaxy Note 3
    Last Post: 11-17-2013, 12:13 AM
  4. Draw on photo change ink color
    By ccpopham in forum Samsung Galaxy Note 3
    Last Post: 11-16-2013, 07:42 PM
