1. arkadiush's Avatar
    Hi,
    After 4.3 update I've noticed serious problems with battery life. Sometimes battery can be dead after only 10 hours. This is not related to any app and before 4.3 phone worked just fine.
    Today another strange things happen - battery was about 40% and suddenly phone turns off and I had to charge immediately.
    Whats wrong ?
    Wysłane z mojego GT-I9505 przy użyciu Tapatalka
    11-18-2013 06:18 AM
  2. StepW's Avatar
    I found that my battery life is poorer too since the update and one time my battery was at 14% and it just turned off as if it ran out of batteries.
    I don't know what's up but it might make you feel better that it's happening to me too .
    11-18-2013 09:07 AM
  3. arkadiush's Avatar
    Well. ..I don't feel any better. .. Actually on call center they told me to do hard reset which I don't want to do...
    11-19-2013 12:22 PM
  4. STSVA's Avatar
    That's pretty standard advice when having issues with Android updates.
    11-19-2013 12:29 PM
  5. arkadiush's Avatar
    And you think it's good advice? ?:-)
    11-19-2013 12:31 PM
  6. warpdrive's Avatar
    I not only think it is good advice, I feel that in most cases it fixes major problems like yours.
    Just back up everything and then do it. If it don't fix it, just wait for the next update or take it to a Samsung rep at best buy for them to reflash (or your service provider).
    11-19-2013 12:53 PM
  1. After the storms
    By CrazyJimbo in forum Photo Spheres
    Last Post: 12-23-2015, 08:24 PM
  2. update to 4.3
    By Doug Fitton in forum T-Mobile Samsung Galaxy S4
    Last Post: 11-27-2013, 09:35 PM
  3. Problem with Galaxy S2 4G
    By mikey88772 in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 11-22-2013, 10:21 AM
  4. how to avoid the 4.3 update
    By Duard in forum Samsung Galaxy Note 2
    Last Post: 11-18-2013, 04:52 PM
  5. Infuriating Mail notification sounds problem
    By TechAddict in forum Samsung Galaxy S4
    Last Post: 11-18-2013, 02:42 AM
