"system failure" "google play is not working" Frozen system- Problems, PROBLEMS EVERYWHERE
Hey everyone. It's my first post over here and i am not from country but hope you'll understand me.
Thing is:
Couple of months ago ( at the beginning when s4 was out) I bought it and everything was just perfect till last update of android. I was trying to do it but it failed. I had a connection with wi-fi but nothing works as it should. From that time i have a lot of problems with phone. It's frozen almost all the time I am not able to wrote a singe message quicker than in 2 hours from the moment i start, also i have a lot of the informations about Google play. Is not working and i have those communicates 15 times in the day. Next problem is " system failure".
Well i was trying to restart it, take off battery even used other one which i have just in case. I also deleted all of the cache and not used programs which i downloaded by my own. ( all the system thing is not even touched ). When i get to the google play it shows me an update. Again fail.At the end of this day i was trying to find a reason of this problems in settings. everything was just fine, all updates are ok. all the processes on the phone are on minimum so it's just irrational for me.
Well, this post is a last chance before i will make a last restart on the wall. (Yes my mind is completely devastated cause of this, and yes i can do it )
Help?
Thing is:
Help?
