06-29-2017 09:07 PM
29 12
tools
  1. Sanghamitra Das's Avatar
    After update my software there is something named "MiniTouch" which is displayed on my home screen. I had try to uninstall it many times but failed. My handset is samsung Galaxy Young Duos. My screen already is in standard or basic mode according to ur suggestn im also try to switch from easy mode to standard mode again but there's no change it still there. Plz solve this issue and help me. I don't need it.
    Thank u
    09-15-2015 05:44 AM
  2. lisainsa's Avatar
    Dear user the problem is fixed and will not come back
    1. Go to Settings
    2. Go to My Devices
    3. Go to Home Screen Mode
    4. Lastly change it from Easy Mode to Standard Mode, click Apply, the problem will be fixed no need to do anything else. It will work, if it didn't let me know. THANK YOU AND I HOPE IT SOLVED EVERY ONES CONCERN
    Hi there.
    This has not solved my problem at all. When i restart my phone, and i attempt to go onto the home screen that message keeps popping up. It is very annoying as i now have no access to my home screen at all.
    As there anything else we can do to fix this problem??
    12-29-2015 07:58 AM
  3. dcerveralv's Avatar
    I was able to fix the problem by formatting my sd card.
    Remove your sd card and try using your phone. If your phone works fine after doing so, then the SD card might be the culprit.
    To format your card, go to settings, more, storage, and format sd card.
    But remember, you will lose all your data on the external SD card.
    01-16-2016 09:10 PM
  4. Jerry D D's Avatar
    I have a Galaxy S4 and and was having problems getting rid of the Easy Mode view even tho it showed I was in Standard Mode. Here is what I had to do to get the phone to show Standard Mode:
    Settings - My Device - Personalization - Easy Mode - here is where I had to click on Easy Mode then Done. Now I went back in to Easy Mode and clicked on Standard Mode. This fixed my problem. Basically all I did was cycle through both modes so it would recognize the Standard Mode again.
    06-29-2017 09:07 PM
29 12
  1. My note 2 screen is turning blue, what is wrong?
    By Jevgenij Gerasimov in forum General Help and How To
    Last Post: 01-13-2014, 03:11 AM
  2. 9 little known features in Kit-Kat
    By KevLar72 in forum Android 4.4 KitKat
    Last Post: 12-01-2013, 12:47 PM
  3. Alarm Clock Issues, Help?
    By dylanb1 in forum Sony Xperia Z
    Last Post: 11-30-2013, 12:40 PM
  4. Broke the amoled screen of galaxy s4. What is the best thing for me to do?
    By simonwang12 in forum General News & Discussion
    Last Post: 11-25-2013, 03:25 AM
  5. Moving contacts and setting from S4 to S4
    By chomperoni in forum Samsung Galaxy S4
    Last Post: 11-25-2013, 01:05 AM
