1. Leo Tiittanen's Avatar
    Hi
    I'm new to this forum but recently i bought a 64 gb samsung class 10 micro SD card and now i'm trying to move all my music,videos,pics, etc. to it but it won't recognize them on the phone. When I checked the card again, all my files were "corrupted" like the names had turned to foreign signs and all that kind of things. What to do? Sorry my english I'm from Finland
    11-26-2013 09:07 AM
  2. doohsun's Avatar
    are you using Kies software to transfer the files?
    11-26-2013 09:22 AM
  3. Leo Tiittanen's Avatar
    nope, just drag&dropping
    11-26-2013 09:38 AM
  4. doohsun's Avatar
    try using Kies it's actually better it's free anyways.
    11-26-2013 09:49 AM
  5. Leo Tiittanen's Avatar
    ok giving it a shot
    11-26-2013 09:56 AM
  6. mhinc's Avatar
    Hi
    I don't agree with the current suggestions to use KIES. Even if you do use KIES, and it works, you are only masking the bigger problem of a corruption error. And you don't want that. There is no reason you should not be able to drop and drag to that card in windows, which is the most simple and normal way to do so. unless it's one of two issues;
    1. That card itself is a lemon, try step 2, if that doesn't work warranty the card.
    2. Try formatting the 64gb Card in windows, then try to move your files again, if that doesn't work, and you get the same error, refer to step 1
    Let me know how that works out for you.
    STSVA likes this.
    11-27-2013 11:37 AM
  1. Droid razr battery problems
    By bethany blackman in forum Motorola RAZRi
    Last Post: 12-04-2013, 03:06 AM
  2. Samsung Galaxy Note 2 - SD card trouble
    By bigrig1964 in forum Samsung Galaxy Note 2
    Last Post: 11-26-2013, 09:09 AM
  3. Replies: 1
    Last Post: 11-26-2013, 08:52 AM
  4. Replies: 1
    Last Post: 11-26-2013, 05:43 AM
  5. Galaxy S3 having some serious problems...
    By Captainev in forum General Help and How To
    Last Post: 11-25-2013, 11:53 PM
