03-07-2017 09:57 AM
63 123
tools
  1. miltboy's Avatar
    i had the same problem and here is how i fixed the issue. Prior to this issue the phone was hot to the touch so i assumed it was the battery and I bought a new battery. But to no avail I still had the same issue. Next i replaced the USB charging port. You have to make sure the port is for your phone. Look under the battery and it should tell you which model your phone is and then i went to ebay to order it for like 10 bucks. The first one did NOT work, I still had the same error. I figured I did something wrong or ordered the wrong part. I read on the forums that some people took 3 tries until it worked. Well, it took 2 tries. My phone works and charges now. I just wanted to share this info. I did look to make sure all connector pieces were attached correctly. In the top corner i had a prong that was bent and I reshaped it back to previous shape. Did this fix my phone? i dont know, but what I do know is i took all of these precautions and now my phone works. The freezer trick did not work btw.
    Edit / Delete Edit Quick reply to this message Reply Quote Quote Multi-Quote This Message
    11-01-2015 08:18 PM
  2. Joe Winczewski's Avatar
    After replacing usb board two times I decide to recheck for weyxiang solution #2. I had cleaned away corrosion with rubbing alcohol the first replacement.
    2nd replacement board still no fix. disassembled a 3rd. time and cleaned around the ribbon cable socket removing leftover corrosion with contact cleaner and brushed lightly, FIXED! Thank You ! weyxiang
    11-11-2015 01:59 AM
  3. technometal's Avatar
    I have a solution that works at the moment. I warmed the battery (HB4A3 for HUAWEI G7210, not a smartphone at all) on the glass-ceramic hob at a hot temperature, with a piece of napkin in between, until you see a very slight sign of smoke, then remove it quickly. I put it in my mobile, and it loaded normally. I hope my experience works for you. Thank you
    11-20-2015 07:20 AM
  4. babayevs's Avatar
    Pls help.samsung s4 not charging .battery temperature too low.
    04-03-2016 09:25 AM
  5. Jennifer Overend's Avatar
    It is a software issue ... it does it when either of my batteries are in the phone. Now it has started to tell me when I try to take a photo with flash on. It started on my phone when it was only two years old and after speaking with a repairer - I bought the second battery.
    05-04-2016 12:20 AM
  6. nazihsyauqi's Avatar
    My galaxy s4 (19500) sometimes not charging and give this message: charging puased. Battery temperature too low. I replacment charger and usb port, but The issue not resolved. Can anyone has any ideas?
    05-10-2016 08:52 AM
  7. nazihsyauqi's Avatar
    05-10-2016 11:13 AM
  8. huhsy's Avatar
    charging paused temperature too low
    05-21-2016 02:19 PM
  9. helanzhu's Avatar
    I had the exact same problem but after I charged the battery with an external charger to 100%, I was able to charge the battery internally through the micro USB port again, as if this problem never existed. I'd suggest trying this before spending $ and effort on micro USB port replacement. EH 6-4-2016
    06-03-2016 07:14 PM
  10. janu96's Avatar
    Best fix i have used. .cost effective
    NavRatna: Technology guidance
    08-27-2016 03:44 AM
  11. pramanasamudra's Avatar
    It has a problem in the battery / usb port. So i just brounght it to the Samsung Service Center. Maybe it's just a common problem in the samsung user?
    09-07-2016 06:04 PM
  12. arnie91's Avatar
    Thanks for all the tips.
    I carried out a digitizer replacement. The Flex cable was lost. I tried a rev1.1 which didnt work, then I used another flex cable from a spare S4 I9505 which no longer works. I got all the buttons working, but as the buttons started working, the phone would get a low temperature warning when charging. I got WD-40 Specialist fast drying contact cleaner, which is normally used for car's electrical connections for cleaning them. I sprayed the port, the flex cable circuit board, the battery metal connection points, and the phones battery connection points. I let them try, then blasted them for about 10 seconds with a heat gun to dry it all off. Put the battery back in and the charger worked! No low temp errors.
    Any electrical contact cleaner will work.
    12-09-2016 04:39 PM
  13. sohel mohammad's Avatar
    I'm waiting for best idea and solution.
    Maybe someone can help.
    03-07-2017 09:57 AM
63 123
  1. Replies: 21
    Last Post: 06-07-2016, 12:04 PM
  2. Droid DNA: battery or motherboard problem?
    By Zero_Lord in forum Verizon Droid DNA
    Last Post: 01-27-2014, 05:48 PM
  3. BATTERY LIFE - Compared to the MOTO G
    By shahali in forum Google Nexus 4
    Last Post: 01-26-2014, 06:34 PM
  4. charging puased
    By jangeez in forum General News & Discussion
    Last Post: 01-24-2014, 05:30 PM
  5. Why can't I disable "email" from the battery option? It drains 25%.
    By Elysium82 in forum General News & Discussion
    Last Post: 01-24-2014, 01:08 PM
