1. tmozer's Avatar
    Just arrived in SW Florida this morning. Hot (in the 80's) and sunny. I was sitting in the sun outside of my lanai with my Galaxy S4. My daughter tried calling me twice. I only discover that by accident. The phone made not a sound. I thought I had turned sound off. Not so. Also the touch screen would not respond. I took the phone inside and I guess it cooled down because I was finally able to shut down (the box touch to do so registered) just before I was ready to pull the battery.
    Is it common for a Galaxy sitting in the heat and sun to fail like that.
    03-02-2014 01:39 PM
  2. zedorda's Avatar
    Yes that's why the manual has temps it should be operated at and also warns not to leave in direct sunlight. Direct sun light can also have adverse effects to AMOLED displays if left for long periods of time.
    03-02-2014 01:48 PM
  3. electricpete's Avatar
    I knew high temperatures were bad but I didn't know Sammy told us anything specific about it.
    So I looked it up. Here is excerpt from my SGH-i337 manual:
    Battery Use and Safety...
    Do not place your battery in or near a heat source. Excessive
    heating can damage the phone or the battery and could cause the
    phone or the battery to explode. Do not dry a wet or damp battery
    with an appliance or heat source such as a microwave oven, hair
    dryer, iron, or radiator. Avoid leaving your phone in your car in
    high temperatures.
    Keep your Samsung Mobile Device away from….
    Extreme heat or cold
    Avoid temperatures below 0C / 32F or above 45C / 113F.
    03-02-2014 05:57 PM
  4. Reddyksl's Avatar
    I got my S5 2 weeks back, many times I noticed both front and back side getting heated up more than normal. it doesn't happen all the time. has any one faced similar isssue ??
    05-07-2014 07:40 AM
  1. Nexus 7: Screen Issue
    By fightcrazy in forum Google Nexus 7 Tablet (2013)
    Last Post: 05-05-2015, 06:35 PM
  2. Replies: 2
    Last Post: 07-02-2014, 03:13 PM
  3. Issues with ANY launcher never saving default action.
    By RULINGCHAOS in forum Samsung Galaxy SIII I9300
    Last Post: 03-06-2014, 04:06 PM
  4. HTC One: KitKat Bluetooth issue
    By mlish420 in forum Android 4.4 KitKat
    Last Post: 03-05-2014, 09:41 AM
  5. Replies: 12
    Last Post: 03-04-2014, 12:12 AM
