I have a S4 did everything possible , everyone says battery, reset , stop services , yet nothing works . Phone was sucking 30% of battery before re-set (Which I lost all my contact info and everything due to a total factory reset ) and all the other non-fixes . after the reset and stopping auto downloads and running apps , Still screen is at 60% usage even when idol .
Another issue and its a ******* big one since the reset I haven't downloaded anything yet 150mb's was used , and for what ? I stopped all updates , so what's using up all my internet ? another issue try making calls and I have to try 4 times before the call goes through ( don't say dead zone I am not an ***** ) , and during that time my battery goes for 50% down to 12% in a matter of 1 min just trying to make one call .
screen setting is at lowest settings .
Everyone says battery , sim , card , screen settings , and running apps .
Non of them is the issue , did every fix suggested "WHEN I SAY EVERYTHING I MEAN EVERYTHING OK " ( SCREAMING THIS NOT YELLING ) .
My phone is getting so fing hot I am close to burring my hand even while idol . Only thing I can do is shut it off completely , but as soon as its turned on battery drains about 10% every 2 mins .
Samsung has a hidden app set on a timer that uses the battery to over heat the circuitry in order to fry the phone so people are forced to by a new one every 2 years after the warranty expires ( o but its not malware because its a Samsung app were not suppose to know about )
I had my old cell phone for 10 years ran as good as new , would of kept it but it ran on rogers so I couldn't put a Virgin SIM card in it , other wise I would not of bought the S4 ( yup just another way corporations insure people spend money they shouldn't .
Sure the S4 was great 2 years ago , I am told I have no choice but to shell out 700cnd for a new phone ( FYI an official unnamed source said these fones are set up to self destruct after so many hours of usage , and the only way to prevent this is get Samsung to tell you how to stop the process I am calling you out Samsung prove the info I received that one of your own tech's gave me is wrong ) . The only logical issue that the phones can have is a self destruct timer that uses the battery to fry the phone that only Samsung can deactivate .
If your Tech ( who I wont name as that was our deal ) was lying prove it , if not tell use how to deactivate this self destructing process ( I call it malware ).
We will insure the public is aware of this , its in our mandate to reveal to the public misdealing's of corporation's
"We are one , We are many , We are like shadows in the night , We are Legion "
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
