08-08-2018 05:15 PM
105 ... 345
tools
  1. racing4mat's Avatar
    Signed up to say thank you! The phone seemed like it was bricked and after some nail "hits" on the power button it got
    working again! Thank you all!
    10-21-2017 04:26 PM
  2. racing4mat's Avatar
    10-21-2017 04:26 PM
  3. fluffuwa's Avatar
    oh my god so I tried what everyone found to be working (slamming it a bunch, blowing air at it), but it didn't work so then I decided to rip it off
    I thought it was broken since when I put the battery in, it didn't do anything. BUT plugging it into the computer gave the battery charging screen thank god
    so to turn it on, I put a flathead into the power button opening top side and laid it against where I thought the connections were, and 5 seconds later, it turned on
    wheeew
    01-30-2018 05:07 PM
  4. jakamon's Avatar
    When unable to get to boot or even safe boot, when you get at most a 1 second glimpse of an empty battery or every once in a while the word "Samsung" for 1 second, the black again, this might be your problem and solution:
    Problem: Galaxy S4 would not turn on, and would not charge. Plugging in would once in a while show an empty battery for 1 second, then go black (never showed charged or charging battery). Tried power boot (power + volume up + home key all at once) several times. One time saw the Samsung boot msg for 1 second, then black again.
    Several people suggested it was the USB charge port dirty or bent, or dirty battery contacts. Nope. None of the suggestions got me more than 1 second of either battery or "Samsung" then black screen again.
    Cause: When you take the back cover off and look at back of phone, there are 2 pressure switches above and to the right of the battery. (there are also 2 smaller points on left, ignore them). The pressure contact switches are delicate push-down contact switches, that were no longer being pushed down enough, so they were not making contact.
    Solution: Gently lift / bend up the rolled (bigger) end of the switch until it stays just slightly above the indent it is seated in. Remember, these are delicate, so don't brute them, but you do have to bend / lift them a little. Put cover back on, and presto, now it boots, and does everything it should. Can now see the battery was 89% charged but it did not matter until I lifted / slightly bent-up these switches and put the cover back on.
    05-07-2018 11:03 PM
  5. Nassour Kalombola's Avatar
    my phone is doing the same ****. How can i clean this power button? I have my phone opened up, and the button looks mint. Everything around it (on the board) is mint. I plugged just the screen in and it does the same thing when i put the battery in, even though the button isn't even touching anything. I tried pulling the button out slightly with tweezers, and it still doesn't help.
    Edit.. I ripped the button off the board lmao all is working good now
    mayn like charm
    08-08-2018 05:15 PM
105 ... 345
  1. Replies: 9
    Last Post: 07-09-2015, 02:49 PM
  2. Samsung Galaxy s4 for Verizon
    By skipatrol in forum Marketplace Archive
    Last Post: 07-26-2014, 10:33 PM
  3. Knock Knock Code turns off after restart
    By godsidekurt in forum LG G3
    Last Post: 07-22-2014, 09:57 PM
  4. How do I access the clipboard on my HTC ة8?
    By AC Question in forum HTC One M8
    Last Post: 07-17-2014, 10:53 PM
  5. picture real dark on camera
    By mesocyclone30 in forum HTC One M7
    Last Post: 07-17-2014, 10:14 PM
