[Galaxy S4 GT-i9500] abnormal Battery drain HELP !
WaSSooM
Hi all , The problem is clear above .. here are some screenshots ...
I couldn't figure out the exact problem ... (PS : I use my phone for about 2 Hrs a day )
it used to last at least (1d 12h) (from 100 to 0%)
but these days ... every 3 minutes 1% is gone .. and during deep sleep 1 % every 12 or 13 minutes
really ... I can't stay with this horrible drain .. help ?!
(please tell what does that mobile signal in second picture mean !! )
PS : this happened in many ROMs .. ( 3 or 4 and also stock ROM )
rob367
Active member
Mar 13, 2014
31
Im having the same problem out of the android system too. It runs high..usually between 23 to 26% with minimal use. When i unplug mine i loose 10% within a half hour. Cant figure out whats causing this unless its the android system. Hope someone has an answer to your question.
rob367
Active member
Mar 13, 2014
31
Im having the same problem. Loosing 10% in a half hour after taking it off the charger. Android system runs between 23 to 26%. Hope someone has an answer to this problem.
alexcolka
187
Try to turn off gps, wifi off when out of router range, check location settings and change it to power saving mode and check for any app that make lots of system scans. That may help a lot.
Sent from my GT-I9500 using Tapatalk
akbarramadhani12
