I'm in the UK and on the EE network. About 4 days ago I got the software update notification which I accepted. After the update the phone now randomly reboots for no reason. I know it not the battery as it has recently been replaced and its fine. The first time it happened was half an hour after the update was complete and I have not installed any apps since. I tried wiping the cache partition which at first I thought solved the issue but it did not.
The settings screen says Android v 4.4.2
When is the next update out or is there a fix/workaround for this?
Thanks for any help in advance guys.
(I also posted this issue in the ask a question section, no solution as of yet)
