1. Sammy Diab's Avatar
    I know that you guys get these questions a lot, so I'm gonna make it easier by saying I did the whole disable-what-you-don't-need method and I'm left to 2 options:either root my phone and save battery by manipulating stuff in advanced mode like my cpu OR just buy a new battery since my phone is a year old. Here's my battery summary pic (this is with battery doctor which helped save my battery a little)
    Attached Thumbnails Samsung s4 battery draining a little fast for me-screenshot_2014-09-06-08-25-37.jpg
    09-06-2014 09:26 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It would help if we saw a little more info.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    09-06-2014 01:59 PM
  3. NellieRose's Avatar
    Periodically over the last 2 months I have experienced sudden & quick battery drains and also have had 2 occasions where the back of the phone was burning hot while not in use nor charging and 1 occasion with a warning on the screen that the phone needed to be shutdown b/c it was overheating. Never found the cause but I am beginning to wonder if this is somehow related to the device no longer downloading email on 1 of 4 accounts. Maybe it has been trying to synch over and over and failing causing an overheat. I don't have FB but do have Dropbox which I didn't think was the problem.
    09-06-2014 07:23 PM
  4. Sammy Diab's Avatar
    Okay here are updated pictures. I'm not sure if you meant idle time when you said Cell Standby so I screenshotted that.
    Attached Thumbnails Samsung s4 battery draining a little fast for me-screenshot_2014-09-07-18-45-10.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-07-18-44-13.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-07-18-44-28.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-07-18-44-53.jpg
    09-07-2014 07:47 PM
  5. B. Diddy's Avatar
    Ok, that's a start. It would still be better if you let it go from 100% to about 20-30% with normal usage, then show us those screens. This will give us a better idea of what is using battery over the span of a single charge, rather than just a small fraction of that charge.
    09-08-2014 01:24 AM
  6. Sammy Diab's Avatar
    Ohhh, ha I read your reply as "let it drain about 20-30%". Okay I will !
    09-08-2014 09:14 AM
  7. Sammy Diab's Avatar
    Okay NOW I'm ready
    Attached Thumbnails Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-14-50-11.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-14-50-23.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-14-51-48.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-14-53-03.jpg   Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-14-50-41.jpg
    09-08-2014 03:55 PM
  8. Sammy Diab's Avatar
    Attached Thumbnails Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-14-50-33.jpg
    09-08-2014 03:56 PM
  9. B. Diddy's Avatar
    That does seem relatively short battery life. The cell signal doesn't always look great, so that might be part of it. I think the S4 should get around 4-5 hours of total screen-on time per charge, depending on usage, and you're not on track for that. Otherwise, nothing else really stands out. The Android OS and Android System percent usage seems normal to me.
    This probably won't help much, but it won't hurt--wipe the system cache partition, which doesn't erase any personal data: Reset: Samsung Galaxy S 4 | T-Mobile Support
    If that doesn't do anything to help, then it'd probably be best to try a new battery.
    09-08-2014 05:33 PM
  10. Sammy Diab's Avatar
    You mean a factory reset? I've done that multiple times before
    Attached Thumbnails Samsung s4 battery draining a little fast for me-screenshot_2014-09-08-22-38-45.jpg
    09-08-2014 11:39 PM
  11. B. Diddy's Avatar
    No, a cache partition wipe isn't as drastic, and is achieved through the Recovery Menu (see that link I included above). It won't hurt to try it, but I think a factory reset would have also wiped the cache as well.
    09-08-2014 11:49 PM
  12. Sammy Diab's Avatar
    Okay, I did that. I still think I need a new battery so I wanted to ask you this:how do I know I'm buying the best battery on eBay when it comes to OEM, amps and other small details?
    09-11-2014 12:52 AM
  13. B. Diddy's Avatar
    It's tough to know for sure. The best bet is to buy from a known retailer, like Best Buy, or directly from Amazon (not the Amazon Marketplace). So if it's defective, it's easy to return. Random sellers from eBay might not be so cooperative.
    It's always best to get an official OEM battery, but there are plenty of 3rd party battery companies that are respectable. One that comes to mind is Seidio, but there are others as well.
    Make sure that it lists your exact‚Äč phone model in its compatibility list. This is important with Samsung devices, since there are so many variants.
    09-11-2014 02:15 AM
  1. Cant recognize sd card 8gb in samsung s5830
    Last Post: 09-06-2014, 10:09 AM
  2. samsung 3 8 inch tab battery drain
    By Richard Porter2 in forum Ask a Question
    Last Post: 09-06-2014, 08:34 AM
  3. Replies: 2
    Last Post: 09-06-2014, 08:30 AM
  4. how do i transfer auto backup photos on samsung galaxys4
    Last Post: 09-06-2014, 08:07 AM
