1. 0ctan3's Avatar
    The rear camera flash has stopped working. I've tried it with the camera and torch/assistive light apps and it doesn't come on, so I am assuming it is hardware.
    Can I buy a new flash and how easy is it to replace? I've searched and nobody else seems to have had this issue.
    09-08-2014 09:10 AM
  2. STARGATE's Avatar
    I don't think you can get that part by itself, seems to be into the camera housing.
    Do you have insurance or a way to get it replaced?
    09-08-2014 09:30 AM
  3. 0ctan3's Avatar
    The phone is out of warranty, and insurance will only replace the phone, not pay for repairs.
    From what I can tell, the flash is on the motherboard (see pic). I'm wondering if it can be replaced or if I'd have to replace the whole motherboard.
    09-09-2014 12:46 AM
  4. Brad Steele's Avatar
    Check out a YouTube channel by a guy named "LE55ONS" (yes with double 5's). It's where I go before I start any repair to any phone. He does complete tear downs and rebuilds step by step. Clear picture, clear words and clear instructions.
    Lg0Gpro_2_AC
    09-09-2014 04:00 AM
  5. 0ctan3's Avatar
    Thanks, watching the vid is very informative. He only mentions the LED flash in passing though, he doesn't mention if it can be replaced. It looks like I'd have to replace the whole motherboard (if it's even available as a spare), which I'm guessing will be pretty expensive and also I'd end up with a new IMEI etc.
    09-09-2014 04:26 AM
  6. Brad Steele's Avatar
    Only way your gonna know for sure is to pull the MB out and check the back. Make sure you can order the part before you try. No sense in pulling it off if you can't place it, and vice versa with buying the part. Make sure you can replace it yourself. Good luck hope you can get it resolved without loss of data and to much cash.
    Lg0Gpro_2_AC
    09-09-2014 12:43 PM
  7. 0ctan3's Avatar
    I've searched a few parts sites & ebay and nobody seems to sell just the led. Can only find the whole motherboard and it's too expensive. I could buy a used phone for less. So I guess I'll just have to live without a flash until I get a new phone.
    09-10-2014 01:06 AM
  8. Brad Steele's Avatar
    Although I have heard the best pictures taken with cell phones are done so without a flash, I would be Peed if my flash went out. I use it for a flashlight at least 5 times a day.
    Lg0Gpro_2_AC
    09-10-2014 07:15 AM
  9. 0ctan3's Avatar
    I know what you mean. Nothing I can do though. I'm not paying a fortune for a new M/board.
    The only advice I can give is not to drop the phone while you're using it as a flashlight.
    09-10-2014 07:18 AM
  1. Galaxy Note 3 camera stopped working.
    By denisric in forum Ask a Question
    Last Post: 02-21-2016, 11:53 AM
  2. LED Notification Light Concern...
    By Jesus Delgadillo in forum Samsung Galaxy S5
    Last Post: 09-08-2014, 11:34 PM
  3. camera and gellery samson galaxy 8.9
    By dennisparry in forum Samsung Cameras
    Last Post: 09-08-2014, 05:24 PM
  4. camera is not found often on this machine?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-08-2014, 11:48 AM
  5. file migration from broken screen
    Last Post: 09-08-2014, 10:23 AM
