1. blitzgp's Avatar
    I need a smartphone that it is easy to remove the cameras (for security at work). Is there a hole in the back cover for the camera/flash, or is there a clear lens so that if I remove the camera there isn't a gaping hole to the internals? Thanks!
    09-13-2014 12:55 PM
  2. STARGATE's Avatar
    I'm not sure I understand, are you trying to remove the cameras out of the phone?
    I don't think you can, well, you might after a great hassle. I don't think is worth it.
    09-13-2014 03:23 PM
  3. blitzgp's Avatar
    Yes, I am going to remove the camera from the phone, and it is very easy with simple youtube videos to show how. I just need to know if the rear cover has a built in window covering the camera, or it relies on the camera module itself to seal the phone.
    09-13-2014 04:00 PM
  4. Bosbouer's Avatar
    The stock back cover has a gaping hole in it as does all replacement covers/cases that I have seen. If you are allowed a cell phone but no camera attached what arexyou going to do about the front facing camera?
    Rather get a cell phone without a camera (if such an animal still exists)
    blitzgp likes this.
    09-14-2014 12:31 AM
  5. blitzgp's Avatar
    Front facing camera is even easier to pull, as I don't have to pull the mainboard out to get it out.
    09-14-2014 10:16 AM
  6. UnlimitedEra's Avatar
    Try the galaxy s3. My camera back then wasn't working and I fixed it myself. It was pretty much easy to take off but I did not taking off the front facing camera. Btw why not ask your manager for a work phone? He'll probably provide you either an iPhone or a blackberry
    09-16-2014 06:18 AM
  7. Slashyou's Avatar
    S4 should be good for that.
    09-16-2014 09:51 AM
  1. Android 4.4.4 - camera not working
    By beardking in forum Sprint Samsung Galaxy Note 3
    Last Post: 09-22-2014, 07:58 PM
  2. Wireless charging battery cover
    By chippy19977 in forum LG G3
    Last Post: 09-15-2014, 05:28 PM
  3. galaxy s4 sd card is blank or has unsupported filesystem - 32GB
    By Phil Recchio in forum Ask a Question
    Last Post: 09-13-2014, 05:59 PM
  4. Battery drain over 20%/hr
    By ahooper239 in forum Ask a Question
    Last Post: 09-13-2014, 12:34 PM
  5. Replies: 0
    Last Post: 09-13-2014, 11:06 AM
