1. Danield2701's Avatar
    Hello,
    An hour ago the phone turned off, I thought that the battery died so I put it in charge.
    Now I tried to turn it on but it only loads until the "Samsung Galaxy S4 GT-I9500" and then turn off and a second later tries to turn on again by itself (shows again the image of "Samsung Galaxy S4 GT-I9500") and turns of again repeatedly.
    I tried to remove the battery and put it back but it automatically starts to turn on and off.
    Please HELP
    09-16-2014 04:19 PM
  2. Claytondwson's Avatar
    Sound like an issue with the battery not taking/holding its charge. Do you have a friend or colleague with the same handset so you can test the their battery to confirm this. Try whiping the battery connectors on the battery and at the back of the phone.
    09-16-2014 05:09 PM
  3. Danield2701's Avatar
    I tried another battery and the problem is the same
    09-16-2014 11:18 PM
  4. Joe Vile's Avatar
    Can u boot into recovery (vol up + power + home buttons)? If you can do so, wipe data /factory reset. Don't worry about numbers texts etc they will all be backed up to your Google and Samsung account.
    09-17-2014 01:21 AM
  1. Google’s Android Silver Program on hold?
    By Ry in forum Rumored Devices Lounge
    Last Post: 09-18-2014, 09:21 AM
  2. Replies: 2
    Last Post: 09-17-2014, 02:27 PM
  3. Samsung Galaxy Tab 3 (7in)
    By janeenchun in forum Ask a Question
    Last Post: 09-16-2014, 04:46 PM
  4. Galaxy S3: Battery discharging quickly
    Last Post: 09-16-2014, 04:10 PM
  5. storage problem on sony
    By Mostafa Samy in forum Legacy Android & Other OS's
    Last Post: 09-16-2014, 04:09 PM
