1. Raj G1's Avatar
    My Samsung Galaxy S4 has started losing signal randomly and usually turns off right after.
    It seems to turn off just under small amount of stress too.
    The phone has been fine up until last week, I tried a factory reset and the probably still exists.
    It is running 4.4.2 Android, but I'm sure the os isn't the problem as I've been running it for a while now with no problems.
    I did some research and I managed to find another person with the same problem, this person managed to find a way to get it going temporarily till the next time it randomly loses signal or switches off, and that was just by plugging it in the charger.
    I tried mine on the charger while it had no signal and it started working again for a bit till it lost signal again.
    09-18-2014 06:00 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I would discuss this with your wireless provider--perhaps they will give you a replacement SIM card.
  3. B. Diddy's Avatar
    09-18-2014 10:54 AM
  4. Raj G1's Avatar
    I don't think it's to do with my sim card, when I don't get signal everything usually stops, wifi, 3g, mobile data.
    09-18-2014 11:10 PM
  5. B. Diddy's Avatar
    How can you tell you lose the wi-fi reception? Does the wi-fi indicator turn off as well? The other signals you mention all have to do with the SIM card.
    09-18-2014 11:18 PM
  6. Raj G1's Avatar
    It loses signal on all, all icons remove and are replaced with the no reception crossed out circle. Sometimes the wifi, works sometimes it all stops. It's a bit odd that it seems to solve temporarily just by plugging in the charger. Could it be battery related?
    09-19-2014 01:45 AM
  7. B. Diddy's Avatar
    Perhaps there are some loose connections within the phone. Have you noticed if the signal drops out with certain positions or sudden impact of the phone? Can you restore it by squeezing it or repositioning it?
    09-19-2014 01:48 AM
  8. Raj G1's Avatar
    Doesn't seem to reproduce or fix the problem by squeezing the phone or repositioning. I contacted Samsung and they told me to send it through to them for a assessment.
    Sometimes just restarting the phone would temporarily fix it.
    Earlier I had my phone fully charged with the charger still plugged in, I took the charger out and it restarted and showed 89%, could be a battery problem I'm thinking.
    09-21-2014 08:04 PM
  9. Raj G1's Avatar
    Phone seems to boot in safe mode sometimes now.
    Battery doesn't seem to sit flush, it is lifted up slightly.
    09-21-2014 09:16 PM
  10. Raj G1's Avatar
    bump
    09-23-2014 01:10 AM
  1. Samsung Note 2 - Metal Bezel Replacement and Leather Back cover.
    By Benny Stephan in forum Samsung Galaxy Note 2
    Last Post: 10-03-2014, 07:36 PM
  2. LectureNotes and Multi-Window problem
    By fastcarve in forum Samsung Galaxy Note Pro 12.2
    Last Post: 09-25-2014, 12:27 PM
  3. sumsung mini s4
    Last Post: 09-24-2014, 12:46 AM
  4. Replies: 0
    Last Post: 09-23-2014, 01:59 PM
  5. Replies: 0
    Last Post: 09-23-2014, 12:56 PM
