1. FontanaHorseman's Avatar
    Is there an app available that can tell Wifi to turn itself on and off when you get to a specific location?
    For instance - when I get home have Wifi turn on then when I leave turn off? Want to do this by cellular location not be GPS.
    Thanks, FH
    09-22-2014 02:10 PM
  2. wjeffries's Avatar
    I'm not sure able an app for that particular purpose, but I know you can do that in Tasker. I have it set up to turn on WIFI when I get to work because or our pitiful cell coverage at work. When I get to work it automatically turns on WIFI and when I leave it turns it back off. You can set it to determine location by either or both cell location or GPS.
    09-22-2014 05:07 PM
  3. trucky's Avatar
    WiFi Matic does this for free.
    Easy peasy
    https://play.google.com/store/apps/d...ificellmanager
    09-25-2014 09:11 AM
  1. i just broke my screen on my andoid tab mikona its a 7inch
    Last Post: 12-13-2015, 05:35 PM
  2. Can't send tweets while using Data
    By graciopp in forum Samsung Galaxy S5
    Last Post: 09-22-2014, 09:13 PM
  3. AT&T x3 lines switch to whom?
    By the4ork in forum Other US Carriers
    Last Post: 09-22-2014, 05:04 PM
  4. Can't fiND apps I installed
    By CRE in forum Ask a Question
    Last Post: 09-22-2014, 02:05 PM
  5. Cracked screen, soft keys don't work now.
    Last Post: 09-22-2014, 01:58 PM
