1. wetermommy's Avatar
    My battery is on the charger and losing power. Its on the charger all day and never gets fully charged. In an hr my battery can go from 70% under 25% no idea why its happening. My Morphie case usually can charge my 5% all the way to 90% and now doesn't charge over 60%. I've had the phone replaced not too long ago for network issues but they didn't replace the battery...time to border a new battery on amazon?
    10-10-2014 10:56 AM
  2. mobilerules's Avatar
    Is the battery bulging at all? Easy way to tell is take it out, put it on a smooth, flat surface & see if you can see space under the corners (also if it spins very easily). If so, it's sounds like time for a new one.
    10-10-2014 01:38 PM
  3. alexcolka's Avatar
    Also check if your charging port (pin) is not damaged.
    Sent from my GT-I9500 using Tapatalk
    10-10-2014 02:41 PM
  1. Moto X 2014 Voice To Text Not Available Via Moto Assist?
    By The Singularious in forum Moto X (2014)
    Last Post: 12-05-2014, 11:20 PM
  2. Replies: 1
    Last Post: 10-11-2014, 02:37 AM
  3. Replies: 1
    Last Post: 10-10-2014, 10:42 AM
  4. Replies: 0
    Last Post: 10-10-2014, 10:39 AM
  5. Replies: 0
    Last Post: 10-10-2014, 10:33 AM
