1. kphtaco94's Avatar
    I dropped m phone in the toilet.. yes the toilet. It will come on, I can hear it boot up, messages come through, and I can turn the volume up and down. but I can't see anything. So about how much would it cost to fix it?
    10-20-2014 07:50 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! That's hard to say, because multiple components could be damaged. Clearly, the screen would need to be replaced. But it's difficult to know if other things might be damaged, like the microUSB port, the buttons, the speakers, etc.
    10-20-2014 10:47 AM
  3. Richard Borgner's Avatar
    My guess is that it would be cheaper to buy a refurbished phone. Good luck however you decide to go.
    10-22-2014 09:56 AM
  4. robertd0619's Avatar
    Same here probably cheaper to get a refurbished or used one.
    Sent from my SGH-M919 using Tapatalk
    10-23-2014 12:32 AM
  1. Want to swap my ipad air for a Samsung tab
    By Fyer in forum Samsung Galaxy Tab S 10.5
    Last Post: 10-22-2016, 04:50 AM
  2. Best PC to Android file uploader
    By Jon12345 in forum Android Apps
    Last Post: 10-21-2014, 11:44 AM
  3. Replies: 11
    Last Post: 10-20-2014, 09:42 PM
  4. How do I download Whatsapp For Pc - Windows 7 or Windows 8/8.1?
    By Param Khiva1 in forum General Help and How To
    Last Post: 10-20-2014, 11:40 AM
  5. How do I view knox files in my files?
    By sgrao_n in forum General Help and How To
    Last Post: 10-20-2014, 04:44 AM
