1. hegdesaspect's Avatar
    Hi
    Is there any compatibility issue between Sony SBH-80 Bluetooth Headset and Samsung Galaxy S4?
    The Play/Pause and Prev/Next buttons of Sony SBH-80 do not work with Samsung Galaxy S4. Only the call Receive/Reject and volume Up/Down buttons work. What could be the reason? Has anybody come across such issues with any other Bluetooth headset with Samsung Galaxy S4? Any Solution?
    Here are the troubleshooting I have done so far:
    1. Unpair all bluetooth devices and try afresh with Sony SBH-80
    2. Clear both data and cache of "Bluetooth Share" and "Bluetooth Test" under application manager
    3. Disable "S Voice" under application manager
    4. Boot in Safe Mode
    5. Re-set Sony SBH-80
    6. Try other music apps like PowerAmp in addition to the stock one
    7. Try with helper apps like "Headset Droid". This app has a kind of debug mode to detect bluetooth headset key presses and it does not detect any key press including the working call Receive/Reject and volume Up/Down.
    8. Tried installing Sony Smart Connect official app to check if that helps.
    None of the above steps (individually or in combination) have helped so far. Whatever I do, the Play/Pause and Prev/Next buttons do not work.
    However, the same SBH-80 works absolutely fine with my Samsung Galaxy K Zoom, Apple iPAD-3, Dell XPS Laptop and JVC Car Audio. It works fine with other devices (tested by my friends) like Xiaomi Mi3, Micromax phones, etc.
    About My Galaxy S4-
    Model: GT-i9500
    Android Version: 4.4.2
    Kernel Version: 3.4.5-2862327 Sep 24 2014 KST
    Build Number: KOT49H.I9500XXUFNI2
    Rooted: No. Stock Android.
    How do I debug more on this problem? Is there any solution?
    Thanks a lot
    11-02-2014 03:48 AM
  1. What are the apn settings for Galaxy s5 on consumer cellular?
    Last Post: 08-31-2016, 01:38 PM
  2. Replies: 1
    Last Post: 11-03-2014, 01:12 AM
  3. Replies: 1
    Last Post: 11-03-2014, 12:46 AM
  4. Replies: 1
    Last Post: 11-03-2014, 12:41 AM
  5. Replies: 0
    Last Post: 11-02-2014, 03:26 AM
