1. tyomies93's Avatar
    So yeah, today I witnessed the weirdest of all problems. My buddies complain they cant hear me when talking on the phone. I tested it myself with my gf's phone and my voice was clearly really low. But when recording via voice recorder/ whatsapp, the volume is completely normal.
    I opened the phone up, checked that everything was ok with the mic and closed it. Same result.
    Any ideas how to fix this? Anyone else sharing the problem?
    Thanks.
    EDIT: Happens all the time.
    EDIT 2: Factory Reseting solved the problem for 1 day. Then it started again.
    11-07-2014 06:36 AM
  2. Gekko's Avatar
    Thanks.
    does it happen intermittently or all the time? if intermittent use speakerphone as a workaround until a permanent fix.
    11-07-2014 06:55 AM
  3. tyomies93's Avatar
    Happens all the time, must be a software issue rather than hardware?
    11-07-2014 08:40 AM
  4. Gekko's Avatar
    if all else fails try a factory reset. then resync reinstall everything back manually. PIA but it might work. make sure all of your stuff is backed up first. sync with Google Account, Dropbox etc.
    good luck.
    The Off-topic Referral Thread - Free Cloud Storage Only!!!!! - XDA Forums
    11-07-2014 08:49 AM
  5. tyomies93's Avatar
    Worked fine for one day after the factory reset. Then the problem started again. Again it works perfectly fine when recording and keeping the phone on ear. But when someone calls / I call, the volume is way too low to hear anything.
    11-11-2014 03:17 PM
  6. Kostadin Georgiev's Avatar
    Hello,
    I have the exact same problem with my galaxy Alpha. When i'm in a call the other guy can't hear me.
    I think is hardware problem, or if is a software how to fix it...
    10-10-2015 04:57 AM
  1. My phone is not vibrate in call, somebody help me?
    By quanghuyvl in forum Ask a Question
    Last Post: 11-07-2014, 12:51 PM
  2. My phone can't chat with tango when connect wifi, help me?
    Last Post: 11-07-2014, 12:47 PM
  3. Replies: 1
    Last Post: 11-07-2014, 12:15 PM
  4. Replies: 1
    Last Post: 11-07-2014, 05:51 AM
