1. lmb02's Avatar
    A couple of days ago my S4 popped up a message about needing to download some Samsung app to handle docking. Except I don't have a dock. Just usb cables in the car and on the nightstand for charging. Now when I plug in a cable it says it is docked... constantly. Screen keeps popping back on to tell me dock is connected. Before I went to settings and turned off the docking sound the bloody phone was chirping constantly.
    Any idea what I can do to tell it I don't have a dock and stop telling me it is connected?
    Thanks
    11-08-2014 01:27 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is there any debris in the microUSB port?
    See what happens if you wipe the system cache partition: Reset: Samsung Galaxy S 4 | T-Mobile Support
    lmb02 likes this.
    11-08-2014 04:52 PM
  3. lmb02's Avatar
    I put the straw nozzle of a can of compressed air really close to the USB port and gave it a good long blast.
    And the problem is gone.
    Grazie mille, B. Diddy
    B. Diddy likes this.
    11-10-2014 09:48 PM
  4. B. Diddy's Avatar
    Wow, that might be the first time that worked for anyone I've suggested it to!
    11-10-2014 11:09 PM
  1. Why my android is showing reverse display?
    Last Post: 08-01-2018, 07:40 AM
  2. Does anyone know how to keep the screen on?
    Last Post: 11-14-2014, 09:24 AM
  3. Att is telling me something completely different, HELP
    By vanpride64 in forum Samsung Gear S
    Last Post: 11-08-2014, 03:43 PM
  4. Replies: 1
    Last Post: 11-08-2014, 02:04 PM
  5. Why are replies to emails stuck in outbox permanently?
    Last Post: 11-08-2014, 12:44 PM
