It started with phone call reception problems at my house. There is usually 2 bars but I cannot make outgoing or receive incoming calls. So I have to switch sim cards to my HTC one just to make a call or check voice mail. That has been on going for about a month. Today, I started not getting a Wifi connection (out of range) when the phone is more than 4 feet from the router. I have restarted the router, restarted the phone. My laptop and other phone works just fine so it is not the router or cell reception. So I am now having weak cell reception and very weak wifi reception.
Any help is appreciated
I have been inside and know how to replace the antenna. Does this wire handle both wifi and phone call reception? BTW , DATA reception seems to be working OK. Maybe a little weak- I don't know but it works when the wifi fails
