1. docsmody's Avatar
    Something is up with this phone. The battery lasts just over 4 hours off a 100% charge. As seen in the screenshot, 68% is used by Android OS & System. The drain occurs while I"m not even using the phone and its just in "standby" mode. I understand it's doing things in the background but this is just ridiculous.
    I tried wiping the partition cache. I've tried leaving the phone off for an hour or so, hasn't helped.
    Any tips / help on what could be causing this? Thank you in advance!
    Sprint Galaxy S4 - Android 4.4.2
    11-16-2014 07:33 PM
  2. Javier P's Avatar
    There are some others threads here with some people reporting the same issue with S4. Most cases related to a recent firmware update by Samsung. Did you have any system update recently?
    Search in the S4 forums for "battery drain".
    11-16-2014 07:48 PM
  1. Does having nfc on actually drain battery
    By mvasquez009 in forum General News & Discussion
    Last Post: 07-02-2017, 03:26 AM
  2. How do I recover my data after I wiped everything with TWRP?
    By Ellol91 in forum General Help and How To
    Last Post: 03-06-2017, 08:50 AM
  3. Android L DNS Change
    By Umut Ozbakan in forum Android 5.0 Lollipop
    Last Post: 12-03-2016, 03:35 PM
  4. Why is battery life so bad on stock?
    By Tex_Norseman in forum Verizon LG G2
    Last Post: 11-18-2014, 02:28 PM
  5. A nice lil Android 5.0 Lollipop theme for Xperia
    By Roy Droid in forum Sony Xperia Z3v
    Last Post: 11-17-2014, 01:11 PM
