After using my phone for a while, it will just randomly crash and reboot, often several times. Most of the time after this, the sound wont work and apps that require sound will crash, or cause the whole phone to crash. Also, apps just crash all the time whether they use sound or not. After restarting several times, the phone sound will usually start working and it will stop crashing, but it isn't long before it does again. Also the times that it starts up with no sound, I have no data connection, making me think it is a problem with the SIM Card, but I don't know how this would affect sound. What is going on???
Things I have tried:
> Soft Reset - Tried several times, sometimes made it restart correctly, but didn't fix permanently.
> Wipe cache partition - Done countless times, sometimes fixed it temporarily.
> Restore to Factory Settings - Worked perfectly for a little while, then started crashing again.
At this point it seems like it must either be an app I have installed, a hardware problem, or my SIM card but I have no idea!! Please help!!!
12-01-2014 11:09 AM
