1. Solomon_Man's Avatar
    All,
    I have a Samsung S4 (SCH-i545) phone which was purchased at Verizon.
    I purchased a non OEM MHL 2.0 To HDMI Adapter and tried it on 3 different TVs. I did verify the input selection on the TV on each. I also tried it "powered" and non-powered using my OEM charger and a non OEM charger. So after all this testing and even using another phone as a test scenario... I assumed the adapter was bad.
    So I purchased another Micro Usb MHL 2.0 To HDMI 3D HDTV Adaptor Cable but this time a OEM one.
    The adapter is a Samsung Model ET-H10FAUWEGWW. Same tests as the first adapter with the exact same results.
    So assuming that two bad adapters from two different vendors is probably not the issue I began reading and I stumbled upon the following adapter;
    Samsung EPL-FU10BEBSTD
    So I guess is this what I need? Has anyone successfully made a Samsung S4 (SCH-i545) connect to a TV?
    Thanks,
    Chris
    12-11-2014 12:40 PM
  1. Replies: 4
    Last Post: 12-23-2014, 04:47 PM
  2. My old HTC ONE is stuck in a Boot Loop but factory reset does not work!?
    By Jonny Swindells in forum New to the Forums? Introduce Yourself Here!
    Last Post: 12-14-2014, 06:17 PM
  3. Android lollipop on Nexus 5
    By Mickey Kidman in forum Android 5.0 Lollipop
    Last Post: 12-11-2014, 07:21 PM
  4. Why am I not able to turn my phone one?
    By Oronno Mahmud in forum Ask a Question
    Last Post: 12-11-2014, 12:24 PM
  5. Replies: 0
    Last Post: 12-11-2014, 12:15 PM
