1. Billy Lowe's Avatar
    I recently purchased a Samsung Galaxy 4S and when I place calls everyone tells me that I sound like I'm under water. Any suggestions on what might be the problem?
    01-02-2015 12:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it sound the same to them if you're using the speakerphone, or a wired or Bluetooth headset?
    01-02-2015 01:00 AM
  3. Rukbat's Avatar
    Or it's a Verizon or Sprint (or one of their network operators) phone, and that's what CDMA sounds like when the signal gets weak. (GSM sounds like autotuning on steroids.) You can't get static from a weak signal with digital communications, the signal "goes digital" - underwater or autotuning, depending on the technology.
    B. Diddy likes this.
    01-02-2015 01:06 AM
  1. Why won't my HTC M8 turn on?
    By cristal alexandra in forum Ask a Question
    Last Post: 01-02-2015, 01:06 AM
  2. Replies: 1
    Last Post: 01-02-2015, 01:02 AM
  3. my camera failed
    By Prasad Raavilla in forum Samsung Galaxy Core
    Last Post: 01-02-2015, 12:09 AM
  4. Why can't I get notifications from Note Edge to My Gear 2?
    By Michelle A Canales in forum General Help and How To
    Last Post: 01-01-2015, 11:03 PM
  5. Should I use my old sim card in new galaxy S5?
    By vicmat in forum Ask a Question
    Last Post: 01-01-2015, 10:51 PM
