1. trd 4rnr's Avatar
    I often have a need to toggle the Audio Output Mode when Docked on & off
    It is a pain to go:
    Settings / My Device / Accessories / "uncheck or check"
    Does anyone know if there is a way to add a shortcut to the Home Screen?
    I use Nova and can add various Shortcuts - but not to Accessories...
    Thanks for your replies.
    01-14-2015 03:23 PM
  2. B. Diddy's Avatar
    Power Toggles should be able to do that.
    01-15-2015 12:42 AM
  3. trd 4rnr's Avatar
    Thanks I'll give it a try.
    01-19-2015 12:10 PM
  1. How to duplicate a calendar event?
    By DrLouie in forum Google Nexus 6
    Last Post: 11-12-2017, 07:26 PM
  2. Update to 24.3.7 installing now, not part of soak test
    By steveg2112 in forum Motorola Droid MAXX
    Last Post: 08-12-2016, 03:31 PM
  3. Do I need to send it back?
    By baknforth101 in forum Ask a Question
    Last Post: 01-15-2015, 08:19 AM
  4. Can I update to 5.0 via OTA and keep root?
    By Silent Infiltrator in forum Ask a Question
    Last Post: 01-14-2015, 03:09 PM
  5. Replies: 1
    Last Post: 01-14-2015, 02:12 PM
