The guest login wifi is not working (GS4), how do I get on the wifi?
gdmill55
Guest Login wifi not working (GS4)
When trying to login to a guest wifi network through the browser with my phone (galaxy s4), the page simply will not connect. I type in all the required info for the login, but when I press connect, nothing happens. It's also kind of annoying that my brother's iphone works perfectly and connects when he tries it (same exact info).
Thank you in advance!
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: Guest Login wifi not working (GS4)
Has this just happened - was it connecting to the guest account before?
Did you recently receive an update to the phone?
Do you have security turned on for Guest mode (do you have to put in a password before connecting)?
