1. AC Question's Avatar
    I have an Galaxy S4 with Android 4.3 already installed. I haven't rooted or anything like that. I only have what software came with the device. I have made sure that everything is updated according to the device (as in I checked for any updates for the software through the device - there are none) and all of my apps are up to date.
    However, my device doesn't open apps such as pinterest, facebook and iheart radio for longer than a few seconds. Skype doesn't open at all.
    Is this a 4.3 problem? If so how can I fix it?
    03-24-2015 08:44 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the cache partition, which won't erase any personal data: http://support.t-mobile.com/docs/DOC-5744
    03-24-2015 03:57 PM
  1. Do android updates slow down phone?
    By Oluwadare Oyadiji in forum Android 5.0 Lollipop
    Last Post: 04-01-2015, 07:29 PM
  2. Replies: 1
    Last Post: 03-25-2015, 02:58 PM
  3. Replies: 1
    Last Post: 03-24-2015, 05:22 PM
  4. Why does my Ace 3 restart when I update an app?
    By ERing Mukan in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-24-2015, 08:32 AM
