guys need imediathelp pls help
sayyam bharadwaj1
Hi guys i had put cm12 nightlies to my t mobile s4 and did a factory rest thinking it would reset some bugs and would run even smother as i did that my s4 has stuck in a kind of loop it keeps on booting into recovery which is teamwin and and just shows the logo of team win the reboots into teamwin again it does this after removing the battery and restarting someone pls help
itguyjax8430
Retired Moderator
Mar 15, 2013
6,822
You need to re flash recovery on the phone that should fix it. That happened to me on my Note 4, I just found a fresh copy of TWRP and used ODIN to flash it back.
Sleezzyy21
