How do I remove the weather and location widget from my lock screen on my Galaxy S4 (5.0.1)?
  • Start date Start date
A
AC Question
On my galaxy s4, android version 5.0.1, I have weather and location.
My question is how do I remove weather and location from the lock screen, while it is secured with a pattern, or at least, how can I change the location, since it shows me an old location ( I've since moved from there ). Thank you!
Re: On my galaxy s4, android version 5.0.1, I have weather and location.
The weather app should have a settings screen to set your location. What weather app are you using?
Okay the problem can be solved as follow
settings > more (on top) > Application manager
slide to the "running apps" swipe from right to left till you see on top running
Go down to Weather open. "force stop" and "disable"
Restart phone.
Ajani
