1. AC Question's Avatar
    My S4 deleted my whtsapp and contacts and i cant use playstore and a lot of samsung essentials after updating to 5.0.1?any help plz
    04-17-2015 08:55 AM
  2. srkmagnus's Avatar
    Try clearing the cache in recovery and see if those issues are fixed. Otherwise, you might need to factory reset. Be sure to backup your data and sync accounts before you do that.
    Let us know how it goes.
    Golfdriver97 likes this.
    04-17-2015 09:36 AM
  3. Golfdriver97's Avatar
    Are any of your contacts backed up? If they are, you should be fine there, and srkmagnus' suggestion of a reset is a good idea. The OS framework probably needs to be rebuilt for those other apps to function.
    04-17-2015 09:42 AM
  1. Replies: 2
    Last Post: 07-14-2015, 09:18 AM
  2. Google Play Services and Google Push Updates?
    By jcp007 in forum Samsung Galaxy S6
    Last Post: 04-17-2015, 06:08 PM
  3. My phone asks for alternative password- What is that?
    Last Post: 04-17-2015, 09:54 AM
  4. How can i unblock a Samsung Galaxy S4 sph-L720T?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-17-2015, 09:04 AM
  5. Updated Battery stats analysis
    By 88horizon5speed in forum Motorola Droid Turbo
    Last Post: 04-17-2015, 08:47 AM
