Hi all,
I received the notification of the new lollipop upgrade (at least I suppose, since it claimed 1gb to update) and I wanted to know about possible battery drain and/or data-wifi problems. Should I wait for the next upgrade or is it safe enough?
My battery life with the s4 isn't that great - I'm currently recalibrating it - so I wanted to know about the promised improved battery life with Project Volta.
Another question, would the upgrade equal to a factory reset, and therefore have a "new install" on the phone or would it be like any other upgrade, leaving data and caches where they are?
Finally, in case of problems with lollipop, is there any way to go back to kitkat without rooting?
