A
AC Question
Hard reset on galaxy s4 external card issues
I’ve got a specific situation for which I’m in need of your expertise, I'm Really annoyed with this issue that i am currently experiencing with my Samsung Galaxy S4 GT 19505 LOLLIPOP 5.0.1 Everytime I use to save files or any applications on my SanDisk Extreme 64GB microSDXC Class 10 UHS-1 the app or the files can no longer be opened by my phone. I also tried to transfer files from phone memory to the microSD card the file or app is no longer available. So what I do is I delete the apps and files that can no longer be of use. I tried to reformat the micro SD card thru my phone, it says that reformat was successful, but when I go back to check on the application or applications or photos that I have deleted manually, I see them again being saved on the SD card evethough I have deleted them permanently and had already used the reformat memory card on SETTINGS > MORE OPTIONS > STORAGE > SD CARD > FORMAT SD CARD. I also tried to reformat the SD card thru windows 7, but i receive an error that the SD card is locked or something and that I need to remove the lock. I am in need of your help badly, I will be waiting for a response from you guys before doing anything on this device. cause I know you would be able to help me on this issue. I don't know if my phone has a virus or if there is something wrong with my SD card. Thank you and God bless you guys!
