1. Kavan Sidhu's Avatar
    Simple question no need for detailed answers. My friend has tmobile S4 with cracked screen. It still works and is not to bad. But he wants to upgrade. He said he will sell me the S4 when he upgrades. But he does not have the original charger. I have a never had a Galaxy S4 before. My galaxy light is 1amp charger. But not familiar with S4. Was that also 1amp or did they up that to 2.1 amp?
    04-23-2015 09:16 PM
  2. Rukbat's Avatar
    It really doesn't matter. The phone will draw as much as it can, up to the maximum it was designed to draw. The OEM charger is 2 Amps, but I have no idea what the phone draws. My Note 3, which also came with a 2 Amp charger, draws 1.2 Amps. If the S4 is also designed to draw 1.2 Amps, it'll take 1.2 times as long to charge as it would with a charger capable of supplying 1.2 Amps or more.
    04-23-2015 10:19 PM
  3. extraclass's Avatar
    The S-4 will tell you onscreen when you plug in the charger, Use the Samsung charger for faster charging. I have found other chargers will charge just as fast but you have to use a suitable cable! If the lightning bolt is visible in the battery icon at the top of the screen you should be OK. The phone will charge slow if plugged into a USB port! You can find Samsung chargers on Ebay for about $10
    04-23-2015 10:55 PM
  1. S4 Mini battery drain after restart
    By jevalladares in forum Hardware Hideaway
    Last Post: 05-23-2015, 05:38 PM
  2. Replies: 6
    Last Post: 04-27-2015, 11:04 PM
  3. Replies: 1
    Last Post: 04-24-2015, 04:48 PM
  4. Replies: 1
    Last Post: 04-23-2015, 08:20 PM
  5. Why can't my S4 connect to data after the KitKat update?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-23-2015, 05:30 PM
