1. AC Question's Avatar
    i tap my wifi icon,it won't turn on, i alrdy go to the settings and enabled it,but it go back to disable
    04-24-2015 07:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try wiping the cache partition: http://support.t-mobile.com/docs/DOC-5744. If that doesn't help, then try Safe Mode (steps are at the bottom of that article).
    It could be a loose connection somewhere--if you're adventurous, you could try opening the phone up and checking (search YouTube for how-to videos).
    04-25-2015 08:39 PM
  1. Embedded Music Player Crushes on Note 4
    By Mprst in forum Samsung Galaxy Note 4
    Last Post: 04-30-2015, 03:23 PM
  2. Pictures in device storage not loading to gallery --- help
    Last Post: 04-24-2015, 11:14 PM
  3. Replies: 1
    Last Post: 04-24-2015, 11:08 PM
  4. Can't type in messaging apps anynore
    By fwellers in forum Ask a Question
    Last Post: 04-24-2015, 07:22 PM
  5. Why is this site so slow on my phone and ipad?
    By f308gt4 in forum Samsung Galaxy S6
    Last Post: 04-24-2015, 07:13 PM
