1. Crunchyhippo's Avatar
    When I type a phone number to call, I get this annoying bloop-bloop sound like dripping water. I've looked and can't find how or where to change or modify it. Can it be done? I have an S4.
    05-05-2015 09:41 AM
  2. mrsmumbles's Avatar
    When you are in the dialer app, look for the three dot menu button in the top right or bottom right corner. There should be a setting to have dialing sound effects or not. Good luck.
    05-05-2015 09:56 AM
  3. Crunchyhippo's Avatar
    There is no three dot menu in any corner of the screen. I don't want *no* sound; just a different sound - like maybe a keyboard sound or something.
    05-05-2015 10:13 AM
  4. anedge's Avatar
    I have been using exDialer, get it on the play store and pay for the pro key, you will not be disappointed and the key sound is a tone like a regular phone. Much better than the stock dialer and the contact list is so much better too.
    05-05-2015 09:52 PM
  1. Replies: 1
    Last Post: 05-05-2015, 02:10 PM
  2. Replies: 0
    Last Post: 05-05-2015, 09:27 AM
  3. Replies: 0
    Last Post: 05-05-2015, 09:14 AM
  4. How do I connect Chromecast to NAS via HDMI?
    By AC Question in forum Google Chromecast
    Last Post: 05-05-2015, 09:05 AM
  5. How do I fix this Gmail Message - Unable to set up an account?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 05-05-2015, 08:53 AM
