Dell Technologies Cyber Savings Event - Up to 45% off
  1. hoperoad's Avatar
    Last week I updated my phone, I don't know what the update is called but I'm assuming it's the most recent one. Anyways the update messed up notifications in my locked screen it used to be just a rectangular box that said "New Message" which was really nice and simple.
    The screenshot that I attached is what it looks like now, not only does it look ugly but my weather app and easy battery app aren't even displaying the correct numbers.
    What I'm wondering is if there is a way to make only message notifications pop up on my lock screen without all of that other stuff. Or if anyone has suggestions for texting apps or something like that. By the way I have already messed around with stuff in the "sounds and notification" settings.
    Thanks for your time.
    Attached Thumbnails Locked Screen Notification Problem-screenshot_2015-05-07-09-23-51.jpg
    05-07-2015 09:37 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! This is how the Lollipop update works for the S4. You could try installing a 3rd party lockscreen replacement app from Google Play Store, but I'm not sure how many of them work on Lollipop (most were designed for KitKat and under).
    I think getting rid of the other notifications means turning off their notifications completely (which means not getting notifications from those apps after you've unlocked the phone.
    05-07-2015 04:53 PM
  1. Help, screen does what it wants,how can I fix this?
    By AC Question in forum Samsung Galaxy Tab 2 10.1
    Last Post: 05-13-2015, 11:31 PM
  2. Replies: 6
    Last Post: 05-07-2015, 11:59 AM
  3. Whatsapp is failing to verify my number, what can the problem be?
    Last Post: 05-07-2015, 09:32 AM
  4. Replies: 0
    Last Post: 05-07-2015, 08:43 AM
  5. How can I prevent a screen shut off when using endomondo app?
    By Raoulja in forum Android 4.4 KitKat
    Last Post: 05-07-2015, 08:21 AM
