A
AC Question
My Samsung Galaxy S4 wont charge help please
Okay so My S4 won't charge. The only time it will charge is unless i power it off, but it barely charges then. First the red LED light doesn't show up indicating that its charging it vibrates then shows up the battery and the loading sign then turns back off and then vibrates again a repeats the process. When it is turned on it wont charge at all. I got a new battery figuring maybe its a battery problem but that didn't work also i tried many different charges i don't and this isn't the first time this has happened the first time it didn't charge at all turned on or off but i got a new charger and then it started charging but this is not the same problem. i hope you can help unless i have to just buy another phone..
