11-11-2016 12:30 PM
67 123
tools
  1. ncandroid's Avatar
    I have a Samsung Note 4 cell phone and can not find the Call - Increase Volume anywhere. The problem I am having is when I am on a call the volume is extremely low and I can barely hear the caller. This happened right after Lollipop was installed on my phone. I have taken my phone to Verizon Wireless where I bought the phone and they recommended I take it to the Samsung Experience Expert at Best Buy. Unfortunately, the Best Buy guy was locked out of his computer and couldn't run a diagnostic test to see if it was the hardware or software. It seems everyone is telling me to use my warranty and get another phone. Before I do that I wanted to see if anyone could help me fix this problem; just in case the problem occurs on the next phone I get.
    10-17-2015 06:34 PM
  2. RedDawgEsq's Avatar
    Take it back to the Best Buy guy; he cant use the "locked-out" excuse forever but you will probably have to educate him on the issue. Just make sure you have the URL of this discussion with you so he can come up to speed on the problem. If he can't find the "increase volume in pocket" setting, he needs to turn in his Secret Decoder Ring.
    10-18-2015 12:01 AM
  3. gooch1313's Avatar
    I have the exact opposite problem. I set my volume to silent while at work, lo and behold my phone rings and the volume is there, its on low but disruptive all the same. Driving me nuts!!! Its not the only problem I have been having since the update. Its making me want to give my beloved phone a painful death by metrolink train if it can't be fixed by my tech guy soon.
    11-05-2015 01:21 AM
  4. 1yuteck87's Avatar
    Oh, terrible. Why isn't the operator doing the required patch for this problem. My phone volume goes to zero several times a day.
    The lolipop os also automatically change my notification tones, deletes certain apps or icons etc
    11-11-2015 09:51 AM
  5. jenga4's Avatar
    I had the same problem unchecking answering and ending calls by waving hand over device worked for me.
    12-20-2015 02:29 PM
  6. extraclass's Avatar
    I use an app named VOLUME LOCKER. It locks my volume when I change it and it asks for a verification to save changes. Tap YES and it is locked there until I change it and verify the new change!
    12-20-2015 04:38 PM
  7. Luis1206's Avatar
    My moto g 2 has same problem after rooting
    12-27-2015 10:56 AM
  8. mojo1sunshinegirl's Avatar
    My phone constantly turns the ringer volume down, is there a fix?
    01-13-2016 03:26 PM
  9. extraclass's Avatar
    I do not know of a FIX but I solved this problem with an APP named VOLUME LOCKER. Set your volume and it will stay that way until you want to change it. If you try to change the volume you get a prompt screen that asks if you want to save the change or not! If you do not save the change it will revert back to the original volume you had set after a few seconds! There are other apps that do the same thing but I have not tried them!
    This solved the problem for me!
    02-28-2016 05:07 PM
  10. olsenclark's Avatar
    i am sooo grateful to know theres an app to keep my ringer on. i have dealt with this constant problem with missed calls for 2 yrs.! i just realised that im left handed and yhat big volume button is always in the palm of my hand. HOW MANY LEFTIES HAVE THE SAME PROBLEM?! im just learning my new phone note 4 which seems to be more sensitive than my note 2 .
    02-28-2016 09:22 PM
  11. 55gdlb's Avatar
    I'm having the same problem.
    06-08-2016 02:42 PM
  12. 55gdlb's Avatar
    Factory reset didn't work for me.
    06-08-2016 02:43 PM
  13. 55gdlb's Avatar
    I can't find such a setting. Where is it?
    06-08-2016 02:46 PM
  14. Bm8tower's Avatar
    Have same problem on my NOTE 4 and i dont have setting called ''increase volume in pocket.''
    11-08-2016 04:03 AM
  15. Bm8tower's Avatar
    Can someone help please?
    11-09-2016 02:06 PM
  16. Colandre33's Avatar
    This is the answer for the increasing ring issue:
    https://play.google.com/store/apps/d...increasingring
    11-10-2016 10:37 AM
  17. Bm8tower's Avatar
    so no fix without installing app with ''in app purchases'' ?
    11-11-2016 12:30 PM
67 123
  1. How can I turn off forced encryption that comes with Lollipop 5.0.1?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 06-30-2015, 02:15 PM
  2. Can I update to Lollipop on my Galaxy Note 3 SM-N900W8?
    By Exwrath in forum Samsung Galaxy Note 3
    Last Post: 05-14-2015, 11:24 AM
  3. Trying to find a new launcher
    By Leslie Hatcher in forum Samsung Galaxy S6
    Last Post: 05-11-2015, 11:50 AM
  4. lollipop Camera Problems
    By mrcleary in forum Dell Venue 8 7000 Series
    Last Post: 05-11-2015, 01:48 AM
  5. Replies: 0
    Last Post: 05-10-2015, 06:20 PM
