How can I fix this Android system recovery 3e Stuck?
Usui Takumi1
Android system recovery <3e> Stuck
So my phone battery went out, and when i charged it again and tried to launch it it shew me "android system recovery <3e> KOT49H.I9505XXUGNK4
There are the options :
Reboot system now (ends in an "error")
Apply update from adb
Apply update from external storage
WIpe data/factory reset (Which i wanna avoid at all cost)
Wipe cache partition (Which doesnt change anything
Apply update from cache (Was empty before and after the cache wipe)
So i was told i had to reinstall the OS or update it, but how do i do that? i cant connect it to my computer and i dont wanna have my data lost, no matter what, what can i do?
I have a Samsung Galaxy S4
Re: Android system recovery <3e> Stuck
Welcome to the forums. In my experience, if you reinstall the OS through Odin, it will do a Reset anyway.
Have you tried pulling the battery for about 10 minutes and trying again?
